fix front bumper - EM1
Old May 23, 2008 | 07:15 PM
inaety's Avatar
Default fix front bumper - EM1
Hello, I guess I screwed up my front bumper from parking or something. I really have no recollection of hitting but. But here's the deal. I have an EM1 and the front right part of the bumper is coming off. There is like this silver thing and I believe that is the issue because i can kind of move it around and stuff. I do have pictures to help explain...
^^ is the silver thing and the wheel from far away
There it is close up, as you can see it is screwed in but I'm not too sure about how it all works.
Thank you
Old May 23, 2008 | 07:58 PM
inaety's Avatar
Originally Posted by freakasis
well the bumper is actually broken, so without a sheet metal screw going into the fender or some glue, its gonna stay on correctly
I didn't really understand that. the bumper is broken so without modification it will stay on?
Old May 23, 2008 | 08:35 PM
freakasis's Avatar
my bad, this is what i meant:
well the bumper is actually broken, so without a sheet metal screw going into the fender or some glue, its NOT gonna stay on correctly
how it works:
a screw goes into a plastic piece* that goes through a piece of sheet metal and then through the bumper into the fender. but since the bumper is broken nothing will hold for very long...its a common problem with hondas.
*when the screw is tightened the plastic splits, causing expansion, keeping it in place...like a molly does in plaster, only reusable.
Old May 23, 2008 | 08:38 PM
inaety's Avatar
how would i put a sheet metal screw into the fender? put it like straight up through the bumper into the top part?
Old May 23, 2008 | 08:43 PM
freakasis's Avatar
yeah, but pre-drill a small hole in the fender (where the arrow is) and bumper so you dont accidently mess up the visible parts.
Old May 23, 2008 | 08:46 PM
freakasis's Avatar
also it looks like yours was rigged previously. you might be able to re-use the current rigging and do away with the sheet metal screw.
Old May 23, 2008 | 08:58 PM
inaety's Avatar
yeah it is, the metal stripe is the rig he used. I'll look into it. a guy on Honda-tech said to weld it
Old May 24, 2008 | 10:43 AM
zeroboost1's Avatar
You could weld it but then your taking a chance on screw up the paint like freakasis said you could fab up somthing with the old rigged up pieces if you need help lmk and good luck let us know how it turns out.
Cory
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old May 24, 2008 | 11:03 AM
inaety's Avatar
Okay I will. Right now it's sitting in the rigged piece alright. but i want it fixed correctly
Old May 24, 2008 | 11:18 AM
freakasis's Avatar
the only "correct" way is to buy a brand new oem bumper and get it primed and painted....but i dont thats what you wanna do. hahaha
as long as its not gonna come off again it doesnt really matter. the "original" ghetto rig might hold it for months. and a sheet metal screw with a washer on it along with the ghetto rigging might hold it for years.
