turbo b16 vaccum question
im in the middle of boosting my b16 ef and im not sure what vaccum line to use for my bov/waste gate post pics if possible repp returned
MONEY IS THE MOTIVE.
try to get a vacuum source for the bov and wg for two different places.
you can tee into the vacuum line for the fuel pressure regulator and on the intake manifold itself towards the back on the drivers side there should be a vacuum line there that you can tee into
You can tap into any vac on the manifold, but if you want to do it right get a vac manifold like this.......
TunerToys Vacuum Manifold Turbo Honda Civic turbo
You can run your brake booster hose to it and run all your vac lined from it.
Cburke.industries.
Custom suspension bars, metal fabrication.
Cburke.industries.
lmao my thoughts exactly. Get a vacuum manifold and run it off your brake booster vacuum line (before the check valve of course lol).
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
