T04B Turbo For my Honda
I got this turbo from a firend an im thinking its WAY to big.. for a 81.5mm srp/egale rod "Plain "LS" with turbo cams an Big-vicky intake mani' an edlbrock 75mm T/B on E-cTuned
60.a/r,cold
1.15.a/r,hot
50
70
T4 twin scroll,. V-ban
T04B Wet Floating Bearings Turbocharger
Compressor Specs:
3" Compressor Inlet
2.128" or 54.06mm Inducer
2.752" or 69.91mm Major
2" Compressor Outlet
Compressor .50 A.R.
Compressor 50 Trim
8 Blade Propeller Type
T4 Compressor Housing
Turbine Specs:
T4 Type Turbine
T4 4 Bolt Flange
2.539" or 64.50mm Exducer
Turbine 1.15 A.R.
Turbine 70 Trim
2.880" or 73.16mm Major
T4 Twin Entry Turbine Housing
TO4B Turbo
AND A
T04-E
T3-T4Looking for low end drivability and high end power. want the boost to come in about 4k rpm..
WET FLOATING BEARINGS
SPECS:
.57 COMPRESSOR WHEEL TRIM
.50 A/R COMPRESSOR
.63 A/R TURBINE
This is a t3/t4 T04E turbo specs. 57 trim
60.a/r,cold
1.15.a/r,hot
50
70
Compressor Specs:
3" Compressor Inlet
Compressor .50 A.R.
Compressor 50 Trim
Turbine Specs:
T4 Type Turbine
T4 4 Bolt Flange
Turbine 1.15 A.R.
Turbine 70 Trim
TO4B Turbo
AND A
T04-E
SPECS:
.50 A/R COMPRESSOR
.63 A/R TURBINE
Crx built In Memory " Yoairo Diaz " Best time to date 10.7 132mph
http://www.youtube.com/watch?v=bTrtjqanH8g
TR "Old Skool EF" Member #135
("Construido no Comprado")
"Am I not destroying my enemies when I make friends of them?" - Abraham Lincoln
Call me tomarrow and ill give you the info you need lmk.
# in sig
# in sig
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
Cory .M
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.Cory .M
lol that looks like the specs from an ebay turbo. how much power u lookin for?
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
