Going Turbo
Old May 15, 2008 | 03:42 AM
devious creations's Avatar
Default Going Turbo
So i will be going turbo in the next few weeks i have been piecing together a kit and just wanted to run down my list so you guys can tell me if i am missing something. thanks... i have turbo, mani, 450cc injectors, resistor box,chipped p28, intercooler, bov, ic piping, wg,boost gauge, boost controller, oil lines, vacuum lines...Now i plan on installing the turbo myself, i have never turbod a car before so im a little nervous about the install, but i wanna learn and like to do things myself to my car plus im trying to keep the cost down so i can have money for tuning...How hard is it and what are some common problems that people run into when installing the turbo kit? sorry for the long story any help is appreciated
Old May 15, 2008 | 07:05 PM
zeroboost1's Avatar
You have a pm sir.
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old May 19, 2008 | 10:06 AM
amimaxima's Avatar
do you have a downpipe?
do you have clamps and coupler?
you should get an oil pressure gauge
it's not hard to install a turbo kit.
you just need to figure out how you want to get oil. are you going to use a sandwich plate or use a tee fitting off the back of the block.
then you need to figure out how you are going to tap the oil pan for the oil drain. are you going to weld on a bung and screw in a fitting or are you going to drill a hole and put in the barb fitting and silicone on it with a jam nut behind?
Old May 19, 2008 | 12:13 PM
Lay Maha's Avatar
Jaded Mitsu
take your time. Make sure you have another ride to go back and forth to the auto parts store. make sure all your flanges are flat. Get a wideband.
