Running rich
Old Jun 21, 2001 | 04:45 PM
C VeX's Avatar
O2 sensor failure???
Old Jun 21, 2001 | 07:30 PM
BIG_Truck_Driver's Avatar
Wherever I may roam...
All hondas run rich from the factory its safer to run rich than lean. adventually your O2 sensor may fail but if it does your motor will throw a code.
Dont worry about it till you can afford an AFC.
Old Jun 23, 2001 | 07:33 AM
Bill's Avatar
Livin' in Seattle
Running rich on Hondas is normal. They are kept running that way from the factory to act as an octane cushion. If you get one hell of a bad tank of gas or use some shitty grade you wont be in much trouble.
