Treadstone turbo kit?
Anyone ever run this setup? It uses a Turbonetics turbo and wastegate. Other parts look pretty decent. Let me know cause im seriously considering going turbo rather than an n/a build. If these arent very good, i may just piece a kit together. Thanks
Honda Civic SI, B, D, CRX Series Turbo Kit - TREADSTONE PERFORMANCE
edit: i would also upgrade to the 3" dp option and the greddy rs bov
1992 Honda Civic Si: SOLD
2003 VW Gti 1.8t: SOLD
Most recent: 88' B16 Turbo CRX: Totaled
PM me if you know me!
anyone? it doesnt look like a bad kit, i just want more opinions. i dont want to buy something thats not worth the box its packaged in.
I have also seen customers end up having bad luck with their turbonetics turbos out of the box.
I would personally piece a kit together runing a tial wastegate, blow off valve, precision intercooler & turbo. For a manifold anything which is free flowing would be ideal such as a equal length manifold. If your looking to stay on a budget w/ a/c a cast manifold such as the inline pro would be ideal.
well its a b16 in a crx. its gutted, so no a/c. i was thinking about getting the spoolin performance stainless log mani, 3" dp, and dump package. that would only cost like 635. then i need to find a decently priced turbo, but i dont know what would be best. Its a stock internal b16 right now, but could throw in a block guard and arp headstuds if needed. what turbo do you recommend for the 250-275 whp range on stock motor?
SpoolinPerformance Log Manifold Package deal (B and D series only) Spoolin Performance
Concerning a block guard & headstuds. There is no need for those components for your setup.
A standard 57 trim .63 ar housing turbo would work fine for that setup.
what manifold would you reccomend then? and what kind of psi would i be looking at to make my power goal safely, and around what rpm do you think i would have full boost?
Thanks for the help btw, I'll probably be coming to you for tuning when im done.
Psi is going to depend on manifold/exhaust design along with turbo size, intercooler size & design etc.
Spool time also will vary depending on all of these factors.
can i fit a ramhorn mani with a crx radiator? or would i have to use the eg/ek rad.?
the spoolin "prototype" manifold is a very nice peice. And it isnt to big so you might not have many space problems
1998 crv daily beater
That wont work with the stock radiator though. this came from the prototype manifold page: '88-91 Civic/CRX Application Notes: Must use 1/2 sized radiator.
