Sort of having brake problems
Old May 6, 2008 | 04:23 AM
That One Guy's Avatar
01' Integra.. Slowness
Default Sort of having brake problems
I have a 94 civic EX. My parking brake doesn't work, it has disc brakes so my thought is that the previous owner did the swap but did not get the parking brake cables. Where can I get these cables from? I have tried searching but came up with nothing.
Old May 6, 2008 | 04:46 AM
SiR-Drew's Avatar
You may not need to get new cables, you might just have to adjust the ones already on there. Typically when the rear brakes are replaces the parking brake needs to be adjusted.
To do this remove the center console around the parking brake handle, lift the rear end of the car (back wheels clear of the ground), put it on jack stands. On the parking brake handle you'll see a little nut that attaches to a cable. Click the parking brake a couple of clicks and while someone slowly spins the back wheel, tighten the nut untill the back tires start to drag, and eventually stop. Put it all back together and your good to go
Hope this helps you.
BTW: incase you do still need to order the cables here's a link:
Parking Brake Cable Honda 1994 Civic - AutoPartsWarehouse.com
Old May 6, 2008 | 04:55 AM
^Thanks rep'd
I need to check if the cable is even there... I can pull the lever all the way up and feel no resistance whatsoever
Old May 6, 2008 | 06:11 AM
SiR-Drew's Avatar
it sounds like it's stretched way out, or not there. When I replaced the brakes on the back of my car the parking brake was the same way.
BTW: your sig. is pretty creepy, lol. Is that from a movie?
Old May 6, 2008 | 11:03 AM
^ I'm not sure where that .gif is from I just found it on the web.
Also if I was to find out that I have no cables at all what will I need to get from that site? Keep in mind that I have disc breaks but unfortunately I don't know what car they were swapped from or if they were swapped at all. Did 94 EX's come with 4 wheel disc brakes?
Old May 6, 2008 | 11:39 AM
allmotor91da's Avatar
bored
ex had rear disc brakes
i miss my db1
Old May 6, 2008 | 02:11 PM
Thatguysstuff's Avatar
Hey its that guy!!
Wrong...
only Canadian civic ex's have rear discs.
US ones have rear drums...
unless it is a SI...
most people swap the rear disc's from 94-00 integras. or 92-95 civic Si's.
I have a pair of E-brake cables off a 93 Si if you need them.
The Ex's have bigger front rotors. and bigger Rear drums then other civic models.
looks like you can use the ebrake cable off most civics...
http://www.autopartswarehouse.com/details/QQHondaQQCivicQQRaybestosQQParking_Brake_CableQQ19 921995QQBC94405.html
Old May 7, 2008 | 05:53 AM
^ Thanks I might be getting some off a integra (if they fit) on thursday
Old May 7, 2008 | 06:01 AM
freakasis's Avatar
Originally Posted by Thatguysstuff
Wrong...
point being that theyre not neccesarily swapped....they could have came on there stock.
they should fit...make sure theyre not on there first.
Old May 7, 2008 | 06:15 AM
Hey its that guy!!
^ True but rarely have i ever seen one that had them stock.... i think ive seen one...
yeah the teggy e-brake cables should work.
