95 ex wont start...why?
Old May 2, 2008 | 04:32 PM
dizzythunder's Avatar
Default 95 ex wont start...why?
everything is there compression, good diss. everything. but there is no power going to the fuel pump, and i have changed the main relay. what else could it be?
Old May 3, 2008 | 06:12 AM
zeroboost1's Avatar
Are u in L argo if so I will be down there tomarrow to work on a car and could help pm me by tonight if u need help my name is Cory lmk.
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old May 3, 2008 | 07:04 AM
dam, naw im in lakeland but thanks
Old May 3, 2008 | 07:17 AM
sprjit22's Avatar
Rick James bitch
Damn Im in Haines City but, Im booked for a few days or Id help you.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old May 3, 2008 | 07:32 AM
colobiano36's Avatar
fuel pump might be out give me a call 813-234-8746
Old May 3, 2008 | 08:10 AM
sprjit22's Avatar
Rick James bitch
If their isnt power to it then it isnt the fuel pump.
T & C Racing
FT Crew Mascot lol
Old May 3, 2008 | 08:11 AM
freakasis's Avatar
how do you know theres no power to the pump? the pump will only has juice when its priming or when the car is running....not when ist just sitting in the on position. put a tester on the wires under the back seat and watch the tester while you turn the key from off to run. are you sure its not getting fuel? how did you check? fuel pressure gauge? you can also loosen the small bolt on top of the filter and turn the key a few times and see if it sprays (cover it with a rag first to make sure you dont spray the battery)....but if the pump is getting power and yer still not getting gas change the pump....if its not getting power its prolly a fuse or the relay. can you hear/feel the relay click when you turn the key? it should click right away when you turn the key and then click again a few second later to shut the pump off
Old May 3, 2008 | 11:59 AM
i have two civics, i put them nose to nose. took main relay, computer, and distributor off the one the runs... i had a buddy helping me he turned the key and i held the test light, something is stopping the spark and the fuel pump problem... my friend had a bmw that did the same thing and it was the crankshaft pos. sensor but this car doesnt have. what else could it be?
Old May 3, 2008 | 05:13 PM
JoKiE crx4294's Avatar
popeye built!
fuel pump fuse
Old May 3, 2008 | 05:41 PM
freakasis's Avatar
did it just die one day? anything leading up to this? it does have a position sensor but its in the dizzy, and the pump would still prime if that was dead. did you just check one fuse or did you check em all? chenge the ecu fuse even if its looks good. check yer grounds. under the dash and on the thermostat housing, break the bolt loose and then retighten it.
