crx bugs help me out !
Old Apr 27, 2008 | 04:59 PM
tranceologist's Avatar
TR Shop Mod
Default crx bugs help me out !
gotta few bugs i need worked out on my 88 dx crx.
my fuel gauge, brake lights, reverse lights and tach are not working. maybe sumone can direct me down the yellow brick road...
ive put new bulbs, and replaced the brake light switch (used). i put a test light on the 3 wires of the brake light switch and they were dead. is it possible i got another dead brake light switch ?
i think there is a harness off the gsr hydro tranny that is not plugged in. is that y the reverse lights are not working ? how can that b fixed ?
lmk about the other stuff if u can. thanx
is there a sensor for the fuel tank. is it a fuel sending unit ???
where do i begin on the tach ???
lmk guys and gals !!!
Old Apr 27, 2008 | 05:33 PM
zeroboost1's Avatar
Yes the harness on the tranny is for reverse and there is a fuse under the hood that mite be blown for the cluster or the one under the dash hope this helps .
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old Apr 30, 2008 | 03:33 PM
TR Shop Mod
no fuses r blown
Old Apr 30, 2008 | 03:59 PM
EGKID's Avatar
Josh did you guys depin the dizzy connector or anything?? Theres a blue wire coming from it that sends the signal for the tach. When I put an obd2 dizzy on my car the blue wire wasn't pinned correctly and caused no tach signal.
Ricky
Old Apr 30, 2008 | 06:51 PM
TR Shop Mod
the harness was made for the app. i traded powder coating for the harness and was told it was for my set up.
nuthing shuda been touched up there near the dizzy.
not sure wut depin is ?!?! LOL miss type i assume... lmk slick
Old May 1, 2008 | 02:24 PM
TR Shop Mod
nuthing from all the honda owners ?!?!
Old May 1, 2008 | 05:54 PM
integrex's Avatar
the reverse light switch is two wires...yellow and blue i believe. you could allways take the switch out of the tranny and hit it manually to test it.
check your tach wire from the dizzy with an meter or test light see if it works there if it does continue to check then the harness plug then behind the cluster.
and yes there is a fuel sending unit in the tank...you access it from under the rear storage compartment..
by chance do you think you cluster might be bad?
also check your fuse box...the whole thing could be bad....
it happened to a customers car of mine once.
Old May 3, 2008 | 05:18 PM
TR Shop Mod
thanx
Old May 4, 2008 | 01:38 PM
TR Shop Mod
help
Old May 7, 2008 | 07:02 PM
iskate2's Avatar
wears black
ive seen the under hood fuse box go and create multiple problems, and there is a box of some sort behind the under dash fuse box that has been known to cause problems. check the search on honda-tech.com, and i have a parts crx if you need to do some trial and error.
also, I took some pics of the powder coating you did for me. looks fucking awesome. i havent been able to get them online, but if you have a phone that gets pics, i can get them to you anytime. just lmk man ill help you out.
Quote; Stan Marsh from "Southpark", concerning his friends Cartman, Kyle, and Kenny obsessing over facebook:
"You guys are retarded, I'm playing XBOX."
