del sol mileage
Old Apr 21, 2008 | 04:54 AM
redcoats1976's Avatar
Default del sol mileage
ive got a 93 del sol,factory stock with d16z6 auto.it was getting around 35 mpg,and in the last couple of years thats dropped to 30.it has new distributor,plugs,wires,air cleaner,fuel filter and 30 PSI air in the tires.it doesnt have any issues such as smoke from the tailpipe and runs fine with 177k miles on it.should i consider changing the o2 sensor or is something else the problem?(original o2 sensor)
Old Apr 21, 2008 | 09:03 AM
HonkeyDong's Avatar
Every dog has his day.
O2 sensor definitely wouldn't hurt
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Apr 21, 2008 | 09:18 AM
Invader_Zim's Avatar
Typical TR Asshole
+1 14 y/o o2 sensors ptrobably should be changed
ಠ_ಠ Haters gonna hate ಠ_ಠ
Old Apr 21, 2008 | 12:38 PM
ACCLUDE22's Avatar
Exhaust Leak !!!!!!!!!!!!!!!!!!
Old Apr 22, 2008 | 07:49 AM
Thatguysstuff's Avatar
Hey its that guy!!
have you had the fuel injectors cleaned???
what kind of gas are you running?
Old Apr 22, 2008 | 09:08 AM
cleaned last year,i run 91 0ctane gas from 7-11
Old Apr 22, 2008 | 11:08 AM
Hey its that guy!!
Hmm.....
get the motor compression checked..
Also how is the tranny doing...
most honda auto trannys i have had have major problems with higher miles..
Old Apr 22, 2008 | 01:00 PM
TechChild's Avatar
Got Rice?
Good choice on 91 that would have been my suggestions, autos are known for not so great mileage, pop your valve cover off you might have alot of build up. try and sea foam it
Old Apr 22, 2008 | 01:04 PM
89crxsir's Avatar
+1 on sea foam, carbon on top of the valves? suck some sea foam down a vacuum line, like the one coming from your brake booster, and in the oil
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Apr 22, 2008 | 02:56 PM
tranny completely redone by AAMCO a year ago,lifetime warrantee.they were probably high fiving when i left the shop...lets see if they still feel that way in 15 or 20 years(last car was a 1966 pontiac that i restored and kept 23 years).i had the valve cover off and it looked o.k. in there,oils been changed every 3k.
