smokin???
Old Apr 18, 2008 | 06:27 AM
TnippleC's Avatar
Default smokin???
have a 91 ef with a 1.5 smokes really bad with white smoke taught it was the head gasket so changed out gasket with a new head but still smokin any ideas what it could be
Old Apr 18, 2008 | 08:36 AM
Old Renegade's Avatar
Cool Runnings
did you check to see if the head was warped or cracked, cause that could be the culprit.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Apr 18, 2008 | 09:42 AM
My Honda Is Slow's Avatar
No really,....it is
it could be the rings. Do a compression check. Look in the book for that vehicle or just call discount and ask them what the compression numbers should be. they should all be about the same. if its too low then the rings arent sealing properly and letting oil get into the cylinders.
just an idea. a compression tester is only like 20 bucks. you can even rent them for free at auto zone. out down a 20 dollar deposit and they give it all back to you when you return it.
im sure you knew that, but just in case.
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Apr 18, 2008 | 11:58 AM
TnippleC's Avatar
oil would throw out a differnt color of smoke wouldnt it , the smoke smells like fuel not even coolant i changed out injectors already but the car runs fine but smokin badly
Old Apr 18, 2008 | 04:52 PM
No really,....it is
if it was a fuel issue the smoke would be a black or dark color. totally different. you would notice it real quick if it was a fuel issue. but a white, blueish color is for sure oil burning. just do a compression check. It wont cost you anything and it will give a lot of useful info in diagnosing your problem.
