I keep blowing oil pan gaskets?
As the title says I keep blowing pan gaskets. I'm about to go nuts. I've replaced the pcv valve. As far as i know everything is hooked up right. Any ideas would be greatly appreciated. I'm not sure if I've got some vaccum lines crossed or not I eleminated a hand full of them mostly just the ones that went to the firewall because I didn't wire in the plugs into the harness, Car idles fine. thanks much (B18a1 w type R pistons,full floating wrist pins)
while the car is running, remove the oil cap. if there is an excesive amount of pressure coming out, something is wrong. if not check the pan to make sure the mating surface is flat and dont overtighten the bolts.
you should most likely be looking for new piston rings
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
sometimes the rings just dont seat. wether clearances are off or the block wasnt properly honed, or you washed out the rings with too much fuel, or whatever the case may be... seen it many times... that first startup is the most crucial time for a fresh build
Tuning, Builds, Assembly, Turbo Installs, Repairs and More
inductionperformance.com
ALPHA TUNED
without a new hone to set those rings, it will just do the same thing all over again. You need some kind of surface on the cyl. walls to get those rings set.
might be the rings
first things first though
how much did you torque the pan bolts to?
i think they're only supposed to around 8-9 ftlbs
and like someone already said... the oil pan mating surface not being completely flat can cause an issue aswell
i went through 3 oil pan gaskets before i realised there was a raised section in the area of where it was blowing out... i took a hammer to it and flattened it out and have been good for 2 months now
Originally Posted by dan
granted, people are allowed to do what they want to their car. if it makes you happy or pleases you, do it. just dont expect the rest of us to care, approve, or suck your dick for doing it.
TR Stock Steering-Wheel Crew
Member #001
Member #001
TR "Old Skool DA" crew
Member #01.8L
Member #01.8L
