Safe limits- stock GSR internals?
Old Apr 14, 2008 | 12:07 PM
chimmike's Avatar
They call me Harry
Default Safe limits- stock GSR internals?
I'm considering using this excellent GT-R ball bearing T28 sitting on a shelf in my garage on my GSR motor. I'm figuring 12psi on it should be good for about 230-240whp.
What kind of limits are we talking on the stock GSR bottom end? I would think about 300whp would be a good safe limit.....................but you all have more experience than I.
Thanks in advance for the heads up.
Also, if anyone feels kind enough to share, what size are the stock injectors? 250-300cc/min?
01 Sentra 1.8 turbo (sold)
91 Sentra SE-R turbo (sold)
03 350z turbo (RIP)
07 Mazdaspeed3
Old Apr 15, 2008 | 11:05 AM
Xiwei's Avatar
Kung Fu comes standard™
i would probably never boost a stock honda over 8psi daily
get a new head gasket too
Old Apr 15, 2008 | 11:25 AM
chimmike's Avatar
They call me Harry
well, you gotta remember, a GT-R t28 doesn't push the CFM a t3 flanged hybrid does.
03 350z turbo (RIP)
07 Mazdaspeed3
Old Apr 15, 2008 | 11:27 AM
sleepinsol's Avatar
starting over
run it on 9 lbs at the most unless u use a b16 head and a thicker gasket to drop compression. but sotck i wouldnt say anything over 9 and thats WELL tuned!
Old Apr 15, 2008 | 11:30 AM
chimmike's Avatar
They call me Harry
hmm. Next question, LS rods won't work in a GS-R right? They're 1.7mm longer than GSR rods....
03 350z turbo (RIP)
07 Mazdaspeed3
97HATCHY's Avatar
if your only looking for 230-250 hp youll be fine on a stock motor with a good tune
Old Apr 15, 2008 | 11:31 AM
chimmike's Avatar
They call me Harry
any idea on the ls rods in a gs-r?
03 350z turbo (RIP)
07 Mazdaspeed3
Old Apr 15, 2008 | 12:32 PM
mtber's Avatar
Stock gsr/itr/ls/d16 injectors are 240cc.
LS rods will only work in a gsr if you have an ls crank.
Stock internals can handle 300 whp on pump gas without an issue, however the limits of the stock bottom end is going to be the cast piston ringlands.
Do not rate the limit of a setup by PSI....
Have your tuner advise you as to what your setup's limits are.
Old Apr 15, 2008 | 12:40 PM
sleepinsol's Avatar
starting over
^ there ya go folks. an answer from a man thats been there and done that.
Old Apr 15, 2008 | 02:50 PM
chimmike's Avatar
They call me Harry
thanks. I know not rating by psi as turbos vary greatly in cfm from one to another.
I figured 300whp would be the limits. And yeah, good old cast pistons and high ring lands.
looks like i'll be lookin for gsr forged rods and some 9:1 pistons eventually.
03 350z turbo (RIP)
07 Mazdaspeed3
