Carb to fuel injected?
Does anyone know of a good shop that will finish my project i have a 87 crx and the motor has been swaped out for the si but i need to take the old carb wiring harness out and route the new fuel injected and also get a fuel pump and maybe run new fuel lines.I dont really have the time to and since its just going to be a dd till i finish my other crx, i was thinking of just paying someone to finish it have and ideas??
wow i remeber trying to do this,then said fuck it not worth it,there is alot of wiring to do,along with changeing out all the fuel lines do to injection will blow the other ones,its just not worth it im sorry,if your set on doing it then do it yourself it will cost you hundreds to get it done by a shop
i love AUTOZONE
i love AUTOZONE
im willing to drop a few hundred dollors to get it up and running and have it done right i work alot and i would lose more money taking time off to get it running then i would if i paid for someone to but im trying to sell it just not having any luck id love to keep it but time is a big issue with me and i have a 90 crx with a b16 that has been giving me issues
https://www.tamparacing.com/forums/c...87-crx-si.html
here is the link to the car
i just got through with a carb-efi conversion, and its way more then a few hundred dollars worth
wiring alone would be a few hundred dollars, depending on your fuel line, i wasn't going to screw with the stock bullshit so i ran a SS line from the pump to the fuel rail and put an inline filter in it, and that whole setup was like $150
i'm not trying to discourage you, if i can do it anyone can do it, but i think a few hundred dollars is low for the work involved
did you keep the stock tank or swap it out i was thinking maybe swaping the tank for the si that has a built in fuel pump would be a better idea and then just run a new line to the fuel rail? This is all new to me so bear with me.
my carb pump was in tank, so i just replaced it with an Si pump, but the tanks are different in that the EFI tank is baffled so its rumored that you can run out of fuel on hard accel, braking, cornering...etc, but i have yet to run into that issue yet
i found it much easier to run a new stainless SS line for my high pressure feed line, and used my old low pressure feed as my new return
new filter
but i've encountered a new problem, as my brake and fuel lines all ran through the car, there is no area for them under the car, so now thats the lowest part of the car at a point
but its much simpler this way then to try and use the stock line, the stock requires dash and heater core removal, as well as the addition of the unsightly filter on the firewall
i'll be at trackday tomorrow if you want to look at it
new filter
i love wires
K20turbo EG hatch 10.49@136
street tuned by NS RACING
??check engine light?? Tranny grinds??I fix'em!!
I MAKE HOUSE CALLS!!
SAME DAY ECU CHIPPING
I <3 WIRES
NS RACING (813)842-5517
chipped P28's $125
http://www.youtube.com/watch?v=nbsSp...a_player<br />
http://www.youtube.com/watch?v=koGfpMAvfWk
http://www.facebook.com/neal.sutton.750
I <3 WIRES
chipped P28's $125
