95 civic ex
One day what doesn't run at all - the car or the fuel pump?
If the pump isn't working and you know you have a good relay switch, it could be the pump itself or the wiring.
Had the same problem with an EG once that turned out to be a bad hot wire from the relay to the fuel pump - the one that runs under the carpet by the driver side door. New wire and no problems since.
