need to know wut harness with b20
Old Mar 31, 2008 | 02:32 PM
LS_VTEC_ON_BOOST's Avatar
Question need to know wut harness with b20
i swapped a b20 into a 93 del sol non vtec, i wanna know wut harness i can use to just plug it up and run the car so i wont have a map,tps,o2 or other problems with sensors? or should i just replace the whole engine harness and inside harness if so which harness can i use? any help would be appreciated thanks
LS_VTEC_ON_BOOST
Old Mar 31, 2008 | 03:23 PM
mtber's Avatar
Use the 93 delsol harness. Simply modify the harness for the b20.
Your other option is to get an obd2 integra ls harness and modify it accordingly. (presuming your using an obd2 distributor/alternator/injectors)
Old Mar 31, 2008 | 08:58 PM
top_acel's Avatar
I have a stuttter
ill ask my Honda guys at work and c what they say.
Why tiptoe threw life only to arrive safely at death?
