Dual intank walbro install
Old Apr 3, 2008 | 04:45 PM
  #21 (permalink)
na200whp's Avatar
Powered by BOOST
Originally Posted by 60-1EK
Ghetto...j/k. Steve will TRY TO goes 9s at track day!
Are you spying on me or do you have someone on the inside???
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Apr 3, 2008 | 05:00 PM
  #22 (permalink)
60-1EK's Avatar
Engineer at the source
You forget I work on the inside
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Apr 10, 2008 | 09:46 AM
  #23 (permalink)
Willis's Avatar
how did you wire up the pumps?
Old Apr 10, 2008 | 02:00 PM
  #24 (permalink)
clean teg's Avatar
Need Some Fuel Do Ya?
Old Apr 10, 2008 | 04:28 PM
  #25 (permalink)
InsaneCivicCoupe's Avatar
Retired Ricer...
With some wire, maybe some solder, probably some kinda connectors, and i would assume electrical tape....
I would like to know too, to see what my options are
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Apr 10, 2008 | 07:19 PM
  #26 (permalink)
mtber's Avatar
Go see Shane & Jason at Auto Audio for a relay, power distribution block, wire etc.
Old Apr 10, 2008 | 08:02 PM
  #27 (permalink)
na200whp's Avatar
Powered by BOOST
well I used the factory wire to run one pump . I T'ed off that line to actuate a second relay which has a straight feed off the bat. I measured the voltage for each pump . The factory wire feeds 11.5 volts and the Bat feed sees 13.0 volts. I'm not going to worry about the voltage difference . Later I may run a second relay but for now I'm sure there will be enough fuel for my power levels.
K series on crack
S D M
Old Apr 11, 2008 | 05:50 AM
  #28 (permalink)
60-1EK's Avatar
Steve, I heard that one of our homies just went 6.82@113 mph in the 1/8th. Can let him beat you y0...lol.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Apr 13, 2008 | 05:17 AM
  #29 (permalink)
lzylst's Avatar
Where was the kit purchased? Just for those interested in doing the same thing.
Vance @ 863-604-2139 for any questions
Old Apr 13, 2008 | 12:24 PM
  #30 (permalink)
na200whp's Avatar
Powered by BOOST
Full Blown Motorsports
K series on crack
S D M
