B18B1 Teg Idle problems
Old Mar 30, 2008 | 11:07 AM
brtnboarder's Avatar
get off my jock
Default B18B1 Teg Idle problems
Well my integra ls 97 is not acting right. If its just parked and sitting there on it will stay at about 500 rpm and then will go up to 1000 and drop almost to zero and then go back up and do the same. When im driving i hit the gas and it doesnt want to move and then after a little bit it will pick up and start moving again. Very wierd i dont know what to do anybody know what could be the issue ?
just another slow integra...
Old Mar 30, 2008 | 12:20 PM
DemonCivic's Avatar
is the check engine light on?
sounds like a TPS
Old Mar 30, 2008 | 12:46 PM
Thatguysstuff's Avatar
Hey its that guy!!
+1 sounds like the TPS.
Also could be the Fast idle or cold start valve.
thats how my accord was acting..
Maybe get your fuel pressure checked...
Ive had the problem that the car would bounce around idle but wouldent go anywhere. fuel pump was crapped out.
Old Mar 30, 2008 | 12:51 PM
get off my jock
yea check engine light is on
so what does that mean ? tps ? i gotta get a new fuel pump ?
Old Mar 30, 2008 | 01:01 PM
get off my jock
also forgot to mention that if i turn on my a/c esp to like 4 it stays barely with any life at about 150-200 rpm's
Old Mar 30, 2008 | 01:02 PM
Hey its that guy!!
check the ECu codes to see what is going on. if its the tps it will tell you
no i meant to check the fuel pressure. if its low then your fuel pump may be failing
Old Mar 30, 2008 | 02:05 PM
DemonCivic's Avatar
+1, start by pulling codes. TPS would be a code 7. let us know what you come up with
Old Mar 30, 2008 | 06:35 PM
get off my jock
yeah man haha i went to advanced auto and had them scan it for me. turned out that my fourth cylinder misfired so all i had to do was buy a new spark plug. I bought all four and it was fine changed them myself right there. so yeah pretty easy fix thank god it wasnt anything worse.
