95 civic ex z6 motor
Old Mar 29, 2008 | 10:02 AM
unique intensions's Avatar
Default 95 civic ex z6 motor
Whats up TR, I need some help in figureing out what the hell is wrong with my car. The problem I am haveing is that while I am driving the car turn off and loses power. The check engine light comes on and off, but the funny shit is that when the light is on it wont turn off and it actually drives good. But when the light is off that is when it acts up. When the light is on it throws code 8 and 15 but that is what I cant understand that when the check engine light is on it wont act up or turn off. But some days the check engine wont come on at all and then it drives like shit. Anyone have a info on what could be causing the problem. That shit is driving me crazy.
Old Mar 29, 2008 | 10:09 AM
chi town brat's Avatar
! Ne shab'rud'ni !
just in case someone asks
Code 8
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TDC Sensor (Top Dead Center)
defective circuit or unplugged / defective sensor
Code 15
90-95 88-95 n/a 88-91 93-95 95 88-95 Ignition Output Signal
missing or defective ignition output signal
Source: http://www.hondacivicforum.com/m_45386/tm.htm
DemonCivic's Avatar
sounds like you need a new distributor
Old Mar 29, 2008 | 10:11 AM
! Ne shab'rud'ni !
Pull off your distributor and look for copper wire to be spun around since you have a TDC sensor CEL
When the sensor basically falls off there is nothing really to do but replace the distributor
This is why your car is acting up intermittently due to the copper wire wrapping around and not letting the distributor act properly. Did it to my 91 Hatch Dizzy and had to replace it (distributor ).
you may be able to save some $ and find one FS in our for sale section. yea its used but they do last awhile. I replaced mine with my CRX Distributor due to an engine swap I had the part as an extra.
Old Mar 29, 2008 | 11:07 AM
That is what I was thinking but againg guys rep for the both of yall. Thanks
Old Mar 29, 2008 | 11:11 AM
DemonCivic's Avatar
no problem, good luck
feel free to pm me if you have any questions
Old Mar 29, 2008 | 12:57 PM
Thanks man
Old Apr 1, 2008 | 04:33 PM
Yo, I have a question also about my problem when I go to accel the car sputters real bad. Could that be timing or is it all distributor problem.
Old Apr 2, 2008 | 05:52 AM
Bori300's Avatar
Bori300
bump bro good luck
TR 5th Gen Civic CREW Member # 17
TR "Old Skool DA" Member #55
Old Apr 2, 2008 | 01:43 PM
! Ne shab'rud'ni !
did you replace the distributer and now it does this?
