Honda Question.. Need Help!! Again
Old Mar 20, 2008 | 07:46 AM
Thatguysstuff's Avatar
Hey its that guy!!
yeah try reseting your ECu.
Tps can be removed with a Dremel and a flat head screw driver...
i have a few laying around if you need one.
Old Mar 20, 2008 | 08:16 AM
Bori300's Avatar
Bori300
Originally Posted by unique intensions
reset it before replceing
iight bro.. ima do that.. 2 reset it i just remove the fuse 4 the ecu or anything in particular i have 2 do
TR 5th Gen Civic CREW Member # 17
TR "Old Skool DA" Member #55
Old Mar 20, 2008 | 08:18 AM
Bori300's Avatar
Bori300
ok thanx bro i reped u 4 ur help.. ima try reseting it.. ok that how u take it off cuz i looked at it and i was like wtf lol.. how much would u charge me 4 a tps if i do remove iit??? its on a sohc dies that matter???
Old Mar 20, 2008 | 01:17 PM
AccordTypeR's Avatar
to reset computer try unhooking your battery for like 10 minutes, if that doesnt work seen how your car is OBD-1 you'll have to have someone with a scanner to clear it, and Unique Intensions - the TDC sensor is built into the distributor
Old Mar 20, 2008 | 03:46 PM
JoKiE crx4294's Avatar
popeye built!
you can replace the tdc sensor
Can't spell strength without tren
AAS...It's whats for dinner
Old Mar 20, 2008 | 05:05 PM
unique intensions's Avatar
Do I have to go to the dealership to buy the tdc sensor or should I just find one at a junkyard. Also what would cause cel number 15 as well, both of them are causeing my check engine light to come on. Any info will help also timing being off will cause them sensors to act up also. Thanks for the info so far.
Old Mar 20, 2008 | 05:24 PM
  #17 (permalink)
Bori300's Avatar
Bori300
iight bro thanx rep 4 u
Old Mar 20, 2008 | 05:28 PM
  #18 (permalink)
Bori300's Avatar
Bori300
ttt help unique intensions wiit his tdc sensor problem
Old Mar 20, 2008 | 06:41 PM
  #19 (permalink)
Gracias brother, hopefully I get this car running right by the end of this weekend. Cause so it will be 5 speed and I want it at top shape before I do the conversion.
Old Mar 21, 2008 | 05:43 AM
  #20 (permalink)
Bori300's Avatar
Bori300
lol de nada bro.. yea i feel ya bro... wat is it a eg coupe??? its dohc or single cam??? if its the 1 in ur avatar it looks clean bro
