high octane?
Old Apr 30, 2001 | 01:35 PM
95civex's Avatar
Sorta Kinda O.G.
I have heard mixed feelings about higher octane gas...i have heard that it leaves carbon deposits...so whats the deal....good or bad for civics...also i have heard different things about removing the resonator....what is it for exactly and would i notince any difference if i took it off?
Old Apr 30, 2001 | 06:48 PM
b16a2pwr's Avatar
ALLJDM
I honostly believe that every once in a while its good to put the high octane gas in every once in a while. Save your money and put the 87 in more often than not.
Be careful though and make sure that theres not much carbon build up..
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old May 1, 2001 | 11:39 AM
RicerX's Avatar
Icy Hot Stuntin
I dont really think its a good idea to put 87 octane gas in your car but I also dont think its a good idea to use extremely high octane gas. Either way I dont think change octane rating of gas going into your engine. I believe you should use a certain octane rating and stick with it. Personally I always use 92 or 93 octane gas only.
"Ricey Hot Stuntaz" member #001
www.seductivecycles.com
Old May 1, 2001 | 06:27 PM
95civex's Avatar
Sorta Kinda O.G.
hey ..thanks for the replys but...it still doesnt answer the question really....does anyone know what gas is the best for civics?
Old May 1, 2001 | 06:50 PM
KJ's Avatar
KJ
bored at work
It really depends. If you are running a high compresion engine or using any power adders 93 octane is a must. I personally will detonate if I use anything lower than 93. If you are running stock compression on an ex with stock timing 87 will be just fine. If you want to tune it a little and bump your ign. timing then you will have to run 89 or 93.
Old May 2, 2001 | 06:36 AM
b16a2pwr's Avatar
ALLJDM
just fill up your tank with the 104 octane BOOST... (NO REALLY DONT do that)
haha. If your stock i believe that you can use 87 but higher compression does need better fuel.. 93 then...
AIM: jasonbadler
813.508.PLAN (7526)
