Timing Belt
Old Mar 10, 2008 | 08:21 PM
HaZed's Avatar
No more Vtec!
Default Timing Belt
Im lookin to get my timing belt swapped out. Do I need to change my water pump too? I know its suggested but what the pros/cons of doing it or not? I got 65,xxx miles on her now. anyone interested in makin a few bucks? If so, how much? B18C5...I believe the timing belt has never been changed before. If no one wants to do it-recommend any good shops around tampa area that'll do it cheap?
Old Mar 10, 2008 | 08:48 PM
Chin's Avatar
MASTER BREWER:HOT TEA
There are enough people on here that I would say could do it for you AIm MyLifeAsAWhopper he could help you out. If you have the timing belt off I would say do the water pump otherwise you get to do the whole procedure again. Which is not fun.
Old Mar 10, 2008 | 08:49 PM
CEMAYHALL's Avatar
www.CEMayhall.com
You dont "have" to change the water pump but, its easy to get at (when the belts already off) and I would call it "preventive maintenance!"
Old Mar 11, 2008 | 09:26 AM
FC_V8's Avatar
I would changed the water pump too... because i really dont feel like doing the work twice.. just me though.
Old Mar 11, 2008 | 02:20 PM
bobster's Avatar
If its only got 65k miles. I wouldnt change it unless any fluid is seeping from base or shaft seal. I'll change it at my house for $100.
Old Mar 11, 2008 | 02:42 PM
DemonCivic's Avatar
change the water pump. you will already be in there, why chance failure later on.
Old Mar 11, 2008 | 03:45 PM
Sabotage's Avatar
slash
change it for preventative maint and to avoid doing the labor twice, from what i remember the water pump wasnt expensive. your car will appreciate the new fluids and parts.
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
