ls cable tranny
Old Mar 10, 2008 | 03:58 AM
sired00fury's Avatar
K-Series HONDA
Default ls cable tranny
Im doing a b16a2 swap in my 90 ef civic hatch and was wondering if the l.s cable tranny is compatible with it? Also if can i use my stock cables instead of buying modified ones? will they work???.
Old Mar 10, 2008 | 09:00 AM
custom240sx's Avatar
DC Crew Member #1
Yes the ls tranny will work on that setup and the stock cable will work also. Just remember that there are two different types of cable trannies. The input shaft diameter varys depending on the year of the tranny.
Old Mar 10, 2008 | 10:52 AM
K-Series HONDA
What year should i get the tranny off of if the year cause in issue to what type? Thanks man
Old Mar 10, 2008 | 12:12 PM
DC Crew Member #1
Doesnt matter what year you use all I was saying is that the input shaft diameter is different which means you need a different clutch disk. The 90-91 is 1mm smaller than the 92-93 transmissions.
Old Mar 10, 2008 | 01:38 PM
K-Series HONDA
ok thanks man
Old Mar 10, 2008 | 01:41 PM
K-Series HONDA
idk if you read my other post but as far as axles go for the 90 civic do i us 92-93 only? I heard that axle length is an issue?
