Good/Fair/Decent price for ITR/CTR Cams?
Old Apr 23, 2001 | 08:11 PM
Ralph's Avatar
TR Balla Donor Supreme
Whats a good or decent price for the ITR and CTR cams..I am planning on adding the honda oem setup to my 1st gen b16 and I have read that either you should go with the CTR Intake Cam and the ITR exhaust cam..or is it the other way around..or does it matter? Can you use both ITR on both cams or CTR on both cams..or should you use the ITR/CTR combo?
TR Profile
Myspace Profile
Old Apr 23, 2001 | 08:56 PM
Ralph's Avatar
Ok..now using the setup you recommend..in Conjuction with a Apexi-VAFC..will that vtec controller remove my revlimiter..and if so what is a safe rpm to shift at with the new setup. I would have it dyno tuned as well. Also so I would(and not to sound like an complete idiot..im just not 100% sure)I would need to purchase BOTH the intake and exhaust side at the same time along with the ITR springs. Will any cam gear do..is one better than the other?
TR Profile
Myspace Profile
Old Apr 23, 2001 | 09:51 PM
Ralph's Avatar
Any place you would recommed to pick up the ITR parts. Im asumming Ferman Acura for one..but wasnt sure if I should find them used or new. And I dont know if youd know this..but Ill ask anyhow what kind of gains should I expect with the setup. Hp/1.4? Thanks for all the help...Ill be looking to get some dyno time and ecu work real soon.
TR Profile
Myspace Profile
Old Apr 24, 2001 | 03:07 PM
Ralph's Avatar
Sweet...$225 brand new? And it bolts right on the b16? Is there anything else I should get(besides a new gasket) to match the intake manifold? And is Dave the spanish guy in the Parts dept or someone in the install bay?
TR Profile
Myspace Profile
Old Apr 25, 2001 | 06:48 AM
Ralph's Avatar
Sweet...hey John..did you get my PM...I went into my preferences to try and PM you instead of just hitting the PM button so i just typed in your SN name. Im thinking it was sent to you?
TR Profile
Myspace Profile
