Torque specs for B16
Old Mar 5, 2008 | 08:37 AM
Gova-91 EF's Avatar
Default Torque specs for B16
I Need The Torque Specs For The Cam Shaft Holders (cam Caps) B16 Head.... Thanx
Old Mar 5, 2008 | 08:54 AM
civicized's Avatar
20 lbs for the caps in the middle and 7.2 lbs for the 10mm bolts on the four cam end covers.
Old Mar 5, 2008 | 08:56 AM
tegrex's Avatar
torque the 10mm bolts to 7 Ft lbs first
torque the 12 mm bolts to 20 ft lbs in the following sequence be very careful not to torque them too fast or you will snap a bolt off like i did. do it very slowly.
9 5 1 3 7
8 4 2 6 10
Old Mar 5, 2008 | 09:57 AM
Gova-91 EF's Avatar
Thanx
Old Mar 5, 2008 | 10:52 AM
DjNando's Avatar
I would not follow the 20FT pnd torque because it seems to snap bolts in the head. Has happened to more than one person that I know. I would do 15 pushing it.
Old Mar 5, 2008 | 07:29 PM
civicized's Avatar
Spec is 20 pounds. I've always followed spec with no problem, and of course Honda torques them to 20 pounds.
If someone is snapping them off, I would suggest they get their torque wrench calibrated. There is absolutely no reason a healthy bolt going into clean threads in the head would snap at 20 pounds. No way, no how.
Old Mar 10, 2008 | 06:18 PM
94jdmgsrdriver's Avatar
i hear that..un-calibrated wrenches sucks come build-up time and also a problem is that lots of people (as well as my self would) keep re-torquing the same bolts etc and i think once you torque bolts a couple of times.. replace em. just what i feel.
