bad missfirering.....HELP!!
Professional Hustler.
on
i have a jdm b16 in my ef hatch, i was on my way to the bank and it started miss firering almost like i was running out of gas but i had a half tank. when i got there i figured it could be 2 things,spark or gas i checked all my injectors they were fine. then while it was ideling i started pulling my plug wires out in cylinder #2 i pulled it and nothing happend so i shut it off and pulled the plug, i checked to see if it was getting spark by using the frame,and it had a steady stream of spark so then i was clueless. after that i drove it home havent touched it im lost i dont know what i should do next. im tryin to get a hold of a compression tester.
also i know this sounds stupid but it ran fine around turns (to bad i cant just drive in circles )
please help rep will be returned
MONEY IS THE MOTIVE.
on
not positive i check to see if they were leaking and they wereent, how can i check to see if there getting pulse, just unhook them from the intake maniflod and try and crank it?
engine building &best
on
take the distributor cap off
i love AUTOZONE
i love AUTOZONE
on
i just un hooked the injector harness and its ran the same (still sounds like a subby lol) but when i went to put it back on it sounded normal then messed up again, like it kept cutting out. maybe i have a bad injector???
on
if you unplug just one the car will still run,just like if you unplug just one spark plug wire it will still run normal to a point..maybe you have a bad Fpr,or even Tps
i love AUTOZONE
i love AUTOZONE
on
if you unplug just one the car will still run,just like if you unplug just one spark plug wire it will still run normal to a point..maybe you have a bad Fpr,or even Tps..where you located
i love AUTOZONE
i love AUTOZONE
