block weight
Old Apr 20, 2001 | 07:03 AM
Durdan's Avatar
No Ants Drift Member
I know that it would be a bad idea to drop an H22 into a civic because it would cause a wicked
understeer but how about a B20 into a CRX??? Whats the weight difference between the B18
and B20 blocks?
RIP Tim. i miss you, buddy
Old Apr 20, 2001 | 07:45 AM
RONIN's Avatar
Tetris on a stick
i think its somwhere between the difference in weight of a tyco block and a lego block
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Apr 20, 2001 | 09:01 AM
TampaTraps's Avatar
get big or die trying!!
the b20 and b18 share the same block. b20 blocks are just a b18 block resleeved to 84mm pistions and 2.0 crank. so the weight would only be a couple pounds. no more than 30lbs if that.
that's president hussein obama to you :gordy:
Old Apr 21, 2001 | 09:57 AM
RedTampaSi's Avatar
If an LS block only costs $200-400 why does an LS tranny alone cost $1ooo???
Old Apr 21, 2001 | 10:29 AM
RedTampaSi's Avatar
Originally posted by "Someone"
Originally posted by hybridEG
Becase you can get a 90 ls block and use it on any car.but the tranny was hydro you saw not cable.hydro is for 92 and up modles.cables are so much cheaper.you need a cable for projsct rex.
So because Im swapping into a pre-92 I need a cable tranny aka I should be looking for a B18A1 not a b18B1?? That makes things cheaper.
