h22a swap...
I have a 91 accord 5 speed coupe and am thinking about doing a motor swap. I have looked into this swap for a while now and seems really worth it! I have a question though...what kind of motor mounts do i need to get and wat type of h22 motor do i need to purchase h22a1?? I appreciate the help guys...
you have an F22 in there now i'm assuming?
if so its a direct swap, any h22 or h23 will work, you can even use your existing transmission if you want to, mounts are the same for f22, h22 and h23
there really isnt much to it the motor is a direct bolt in. if you are looking for a quick easy motor to put in then use the tranny that you have. so buy a wiring harness ecu and a motor. wiring harness $100.00 ecu $150.00 and a motor is $900.00 shipped to your door.
i once felt bad cause i had no turbo!! then i met a man that had no VTEC.
