How difficult is it to replace a hood release cable?
91 Crx, can't open my hood anymore without 2 people. I've already got a new cable from Honda to put in, but not sure how difficult this will be or if it's easy as pie. Your thoughts, please.
TR "Old Skool EF" Member #012
91 Honda Crx Si & 03 Lightning clone
~*~Ellie~*~
RIP Cisco Ramos, RIP Brian Nichols
~*~Ellie~*~
It may not be your cable at all, you may need adjustment on the latch (that bolds to the center-support). Its adjustable............unlesssss.........u have aftermarket crap like a cheap CF hood that the latch is way off (95% it is) or has been wreck in the past and never wasn't align correctly. Its actually common on CR-Xs the older they get, own a handful in the past to know it just need adjustment! Same goes w/ the squeaky trunk.
The cable is a pain the ass, btw......sorry
Thanks for the info. The cable actually poked me where it meets the lever under the dash, so I know it's breaking. Regardless if that's the only problem, it needs to be replaced. It's been mentioned to me that it may take a few hours, if not more...so I'm not looking forward to this one
~*~Ellie~*~
~*~Ellie~*~
it's not that bad
"THE REAL HONDAMIKE" ASE Master Technician
"Imitation is the highest form of flattery", but clones can get it wrong because we are promoting individuality and being proud of yourself.
again not too bad, or go the "Fuck It" route and ricer hood pin that shit kuz ur tired of reaching under the bumper to release the hood... lol like me!!
image removed from your sig...see forum rules
engine building &best
on
a few hours damn its very easy just remove the 2 10mm bolts holding the latch under the dash take it off the plastic then remove the drivers side wheelLineing jack up the car take the wheel off its all right there takes 5mins to change undo the 4 10mm bolts holding the Latch connect the lil green stubby rebolt it back up and you good to go
i love AUTOZONE
i love AUTOZONE
Or if you cant lift the car and remove the wheel you can take the fender off, its like 6 bolts, very easy..the cable is attached to the subframe in there. Then to get the actual hood latch loose its 5 bolts, 4 up top around the radiator and should be a long piece that runs down the front of the radiator (may not be) and bolts down there with one.
TR Old Skool EF Crew #24
perhaps we'll just wait til she goes back in paint and let him do it
~*~Ellie~*~
~*~Ellie~*~
