rear brake noise?
Old Feb 24, 2008 | 09:00 AM
redcoats1976's Avatar
Default rear brake noise?
my car is a 93 del sol si with OE rear discs.it has always made a light chirping noise when driving around town.the noise goes away when you put your foot on the brake even gently,like just enough to cause the pads to start gripping the rotor without slowing down.thinking it was because the rear rotors are warped i put new rotors and pads on it yesterday but it still makes this noise.i jacked it up again and the rears will spin about 1 revolution before stopping when you spin them so i dont "think" this is a sticking calipher problem.any ideas,is this a real problem or should i just leave the radio on?oh yeah,no play in rear hubs either but they are originals with177k miles on them.
Old Feb 24, 2008 | 02:34 PM
DemonCivic's Avatar
are you missing the little metal brake silencer clips?
Old Feb 24, 2008 | 04:19 PM
no,i even used that crap that goes on the back of the pads too.whats weird is the noise stops when you put your foot on the brake and starts when your foot gets off it,its like i am hearing the pads barely touching the rotor surface as the car goes down the road.im assuming they are supposed to barely touch the rotor when not applied...
Old Feb 28, 2008 | 02:51 PM
bump...thought someone would have an idea.
Old Feb 28, 2008 | 03:08 PM
DemonCivic's Avatar
are you using cheap pads?
sometimes the cheaper pads make noise
Old Feb 29, 2008 | 04:05 PM
ceramic pads,new rotors,and cant find anything wrong...could it be the hub itself squeaking?
Old Feb 29, 2008 | 05:49 PM
DemonCivic's Avatar
is the noise on both sides or just one?
Old Mar 1, 2008 | 03:10 AM
its hard to tell but seems to be from drivers side.that side is also just a little tighter,not much though.any way to loosen it without buying a new calipher as these are about 3 years old?
Old Mar 1, 2008 | 05:45 AM
DemonCivic's Avatar
did the caliper compress completely when you installed the new pads and rotors?
Old Mar 1, 2008 | 08:04 AM
yes,you have to screw the piston back into the bore.seemed like it was identical to the other side.
