h22a4 obd1 questions
Old Feb 18, 2008 | 07:56 AM
cutty2fast's Avatar
boats and hoes!!
Default h22a4 obd1 questions
me and my cuzin are building a 1991 accord with a 97 h22a4 and was wondering what all parts do i need to convert to obd1??? any help would be appreciated, thinking of doin a write up also with pics of the swap
Your fucking slow!!
Old Feb 19, 2008 | 08:55 AM
cutty2fast's Avatar
boats and hoes!!
bump for a lil help
Your fucking slow!!
Old Feb 19, 2008 | 09:05 AM
1nycelude's Avatar
***boosted***
oil pump is different it has a crank sensor in it and the dizzy is different the injectors are different and the o2 sensors. so run a obd1 header obd1 dizzy and if you really wanted to you can do i toga high volume oil pump minus the sensor for obd1 if you wanted to while the motor is out of the car.
i once felt bad cause i had no turbo!! then i met a man that had no VTEC.
Old Feb 19, 2008 | 10:23 AM
cutty2fast's Avatar
boats and hoes!!
what if im running a aftermarket exhaust, just use and obd1 o2 sensor?
Your fucking slow!!
