Broken Valve
on
Broken Valve *PICS*
***UPDATED___PICS***
What would cause an after-market stainless steel valve to shear off perfectly on the stem in a B18B engine at roughly 1300-1500 RPM?
Timing was still good before the motor was dissembled.
Ferrea Valves
Omni Spring and Retainers
'01 ITR Cams
I am thinking defective material.
Pics of valve will be up tomorrow.
Head is/was a ITR w/ P/P
Ferrea Valves
'01 ITR Cams
B20 Non-Vtec Turbo: 275whp/234wtq @ 8 psi 2/10/2007
LS/Vtec Turbo: ???whp/???wtq @ ? psi (Secret )
Tuned by John Vega @ Phearable.net
on
No opinions?
what company
9.81@ 155 - turbo street B18 retired SOLD
9.91@ 144 - turbo street 10.94@ 137 225 50 bfg stock block
9.10@169 - turbo street 24.5 mt
9.38@ 144 all motor
8.76@ 176 outlaw street
www.clutchmasters.com
www.tempestracing.net
9.38@ 144 all motor
engine building &best
on
what retainer and valve spring where you running with it?where they installed correctly how long ago was the head built?what size lift is the cam
i love AUTOZONE
i love AUTOZONE
on
Omni springs and retainers
'01 ITR cams
Car was running for approximately 9 months till the incident.
Timing was still good before dissembling.
Thats hardened valves for you, they break not bend as oem materials will mostly do. if the valves break they dance around in your motor and do damage to the head, piston and sometimes cylinder walls. when they bend the just make a impression in the piston and do no dancing. so with bending and no breaking there is less damage.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
It is just shitty luck.
yeah they could but i figure less often than hardened valves.
No doubt shitty luck
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
on
well least the damage does not look to bad to the head so you maybe in luck there.is the retainer broken?may just been worn valvecotters
i love AUTOZONE
i love AUTOZONE
