Transmisson HELP
Old Feb 16, 2008 | 05:56 PM
McSierra's Avatar
EL DON COLOMBIANO
Default Transmisson HELP
NOT a good day for me... I Changed the fluid and stipped the case. Is there a repair kit? What do i need to do now? replace 1/2 the case? That is NOT my big problem.. I filled it with 3.3 Qts and put the bolt back on with liquid gasget. and it seams to be holding fine.. I then went to move the truck for a test drive it now doesn't move.. HELP
I didn't get the exact measurement of how much came out when I drained it. I have put 4qt in it and it's not going into gear? Forget the bolt issue for a moment. It's not leaking...
IF the fluid is low (1/2 to 1 qt) would that cause it to got go in to gear?
EL DON COLOMBIANO
"Quitting while you're ahead, is not the same as quitting"
Sell me your EG Parts...!
https://www.tamparacing.com/forums/h...wish-list.html
Old Feb 16, 2008 | 08:53 PM
YBlegal's Avatar
Broke not Built
what is the tranny for? i know a honda tranny will go into gear with no fluid at all, so i dont think its the amount of fluid causing the problem. but then again you said "move the truck" so im assuming maybe its not a honda tranny your refering to....more info on the vehicle may help.
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Feb 16, 2008 | 09:03 PM
T4eg's Avatar
u could tap it to pipe thread if u wanna get ghetto
9.81@ 155 - turbo street B18 retired SOLD
9.91@ 144 - turbo street 10.94@ 137 225 50 bfg stock block
9.10@169 - turbo street 24.5 mt
9.38@ 144 all motor
8.76@ 176 outlaw street
www.clutchmasters.com
www.tempestracing.net
Old Feb 17, 2008 | 03:56 AM
McSierra's Avatar
EL DON COLOMBIANO
Sorry, It's a 2006 Honda Pilot. Reverse is the only gear that HARDLY works.. I was able to get it out of the driveway. It's now parked in front of the house.. That was as far as I was able to move it.
EL DON COLOMBIANO
Old Feb 17, 2008 | 03:59 AM
McSierra's Avatar
EL DON COLOMBIANO
HONDA PILOT .ORG - Transmisson HELP Is a thead i started there looking for help..
EL DON COLOMBIANO
Old Feb 17, 2008 | 08:46 AM
HonkeyDong's Avatar
Every dog has his day.
Wow, problems like this on a 2006??
Old Feb 17, 2008 | 08:48 AM
BlackWind's Avatar
Requiem
thats why when you get a new truck like that, the dealer should be the only one to fuck with it.
okay
Old Feb 17, 2008 | 09:09 AM
DemonCivic's Avatar
its automatic i assume. you need more than 3.3 quarts if you emptied the tranny completely. also do not use plain old dextron III. you should use honda atf or add friction modifier to dextron III. g/l
Old Feb 17, 2008 | 11:10 AM
McSierra's Avatar
EL DON COLOMBIANO
Default Resolved
Issue was resolved.. I am an ID10T that is all i will admit too..!
EL DON COLOMBIANO
Old Feb 17, 2008 | 11:23 AM
YBlegal's Avatar
Broke not Built
details or ban!!
