**.:Power Steering Removal:.**
Old Feb 14, 2008 | 06:52 PM
kumar.'s Avatar
wrd.
Exclamation **.:Power Steering Removal:.**
I want to remove the entire power steering system out of my eg hatch. What is the proper way removing the system? If any of you know, or can help me do this let me know. My system has a slight leak to it, and I have to top it off every month or so, thats my reason in taking it out. btw I have a B series swap.
"Success is 99% failure" -Soichiro Honda
Old Feb 14, 2008 | 07:31 PM
jlude90's Avatar
aspiring luder
my post from preludepower after i gutted my steering rack
since Lisa got her 4WS and her old PS stuff didn't work, i took her rack and decided to gut it
Honda-Tech.com: Honda Prelude: Write-up: 4g prelude manual rack conversion
it was pretty easy, done in a couple hours which most of it was me bitching about snap rings, theres some stuff that doesn't come out easily (fall out) but it really wasn't hard at all
so anyways, i tested my old rack yesterday, the TQ required to turn it was 15 lb/ft. as a side note, make sure your column is unlocked, i couldn't understand why i was getting 70+ lb/ft of TQ, yeah....i'm dumb
anyways, my old rack wasn't connected to anything, but the lines were there, all open. so i imagine it was pretty close to the effort required with the lines looped, as no hydraulic lock was created.
so with the new rack in, and set on the ground and pushed back and then in the original spot so the tires were in the right spot, the TQ wrench read about 10 lb/ft, so thats about a 33% decrease in effort to turning the wheel at a dead stop
now i could have done much better tests and all that crap, but i think these ballpark numbers were gotten pretty consistently, so i think its a decent indicator of what gutting the rack is worth, weather or not its worth it to you
Old Feb 14, 2008 | 07:41 PM
mtber's Avatar
Just remove the rack & replace it with a manual civic rack.
Old Feb 14, 2008 | 08:22 PM
jlude90's Avatar
aspiring luder
stupid civics and their all kinds of interchangeability shit...assholes
sleepinsol's Avatar
starting over
+1 to mr. vega. then u dont have to worry about the lines n stuff not having fluid circulate thru them......btw manual rack ratios are slightly different than power ones.
Old Feb 15, 2008 | 09:16 AM
kumar.'s Avatar
wrd.
Tru, well off to hunt for a manual rack then!
Old Feb 15, 2008 | 09:18 AM
DD.'s Avatar
DD.
Administrator
Manual racks are so much better. It makes your engine bay look cleaner, and it doesn't even feel much stiffer to turn. I mean, c'mon, you drive a 2100lb car.
Old Feb 15, 2008 | 09:24 AM
kumar.'s Avatar
wrd.
Besides the fact of the rack leaking all over my garage floor,yeah, thats the reason why I would be removing it. It will make my engine bay look alot cleaner than it is!
Old Feb 15, 2008 | 09:32 AM
Old Renegade's Avatar
Cool Runnings
why not fix it?
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Feb 15, 2008 | 08:53 PM
kumar.'s Avatar
wrd.
^ I do want to do that, but I'm not quite sure what i've got to do to fix it.
