which timing belt do i use?
which timing belt do i use for my motor. i know the b series ones are different sizes. i believe i use the ITR belt.
b16a head
b18a1 block
which belt do i use ?
b16a head
b18a1 block
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
which water pump do u have? if its the gsr/type r water pump then use the gsr or type r belt (both are the same). if its the ls water pump then use the ls belt. the gsr/type r water pumps have 22 teeth i believe and the ls only has 19. so u need to match the belt to the pump.
it goes by which head you have so if you have a B16 head you use a B16 timing belt, by the way YBlegal im selling my slicks let me know if you want to buy them
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
MCOR Automotive LLC
Not correct. The heads are the same height.
Use a Vtec Water pump (22T) and a GSR,ITR timing belt for B18C and B18A/B blocks. Done.
www.lhtperformance.net.
727 344 1800
*Turbocharging* Engine building* Tuning *Intercooler piping*exhausts* headers* clutches ,fabrication and much more
13 years in the same location.
** HONDATA Authorized Dealer+ Tuner **
01 Type R-647whp street car w' AC - Cover of turbo magazine Feb 2008
01 K20a INSIGHT - Cover of Honda Tuning magazine June 2008
2011 KR-Z K20 powered CR-Z -Cover of Honda Tuning magazine April 2011
727 344 1800
or B16 head
MCOR Automotive LLC
MCOR Automotive LLC
nothing different in the head height.....its DECK height. b16 blocks are slightly shorter than b18 so they use a slightly shorter belt than the 1.8l (correct me if im wrong).
the gsr belt will work on a ls water pump.i have a gsr timeing belt on my Ls motor nonvtec: o ) only cause i had a new one laying around...i myself use all gsr belts on all lsvtec..even if i use ls water pumps..
i love AUTOZONE
i love AUTOZONE
