honda clutch
Old Apr 5, 2001 | 10:11 AM
Garrett's Avatar
pfft.....
is it all all possible to adjust a stock clutch becaus emine grabs about 1 or 2 inches from the top and yes i know my clutch is going out but i dont have the money for a good one right now or if someone has a clutch for a 90 civic dx at a reasonable price let me know......
Old Apr 5, 2001 | 10:27 AM
RicerX's Avatar
Icy Hot Stuntin
On my B16a1 you can adjust the setting where the clutch engages...to a certain degree. If your clutch is real bad I dont think it will help too much. But you can give it a try. (Im not 100% sure if your clutch can be adjusted or not.)
Im looking at the pic of your engine in your sig and it looks as if you can adjust it. You see the thick cable that runs horizontally right behind your valve cover? Its the rubber cable that looks like its coming from the driver side and it curves behind your valve cover and down into the bottem of the left side of your engine bay. Follow the cable down to the left side of your block...should be right behind/under your distributer. There should be (there is on mine) a round metal thing about an inch in diameter that has about 6 or 7 notches on it. Youll know when you see it cuz its the only thing on the rubber cable that stands out. Well you should be able to adjust your clucth engagment point to a certain degree by twisting that on to different settings...basically a trial and error thing. Set if on a certain setting and hop in your car and take off in first to see when it engages and just keep doing that untill you get a feel that you like.
If your motor doesnt have this thing im talkin about I feel like a complete moron for writting all this.
Goodluck.
"Ricey Hot Stuntaz" member #001
www.seductivecycles.com
Old Apr 5, 2001 | 05:21 PM
Garrett's Avatar
pfft.....
thank you i would go check it out now but its freakin pooring outside
Old Apr 5, 2001 | 06:17 PM
Garrett's Avatar
pfft.....
okay got out to look at it i found a black knob right there i trued to adjust it but i ccant get that badboy to budge
anyone got any ideas???
Old Apr 5, 2001 | 06:31 PM
Garrett's Avatar
pfft.....
if anyone sees this and can help me further contact me by
aim - scuubidew
yahoo - garnut2
Old Apr 6, 2001 | 12:23 AM
Ralph's Avatar
TR Balla Donor Supreme
you just need to take the battery out and get in there with some pliars and break that sucker free and adjust it to where you want it i have done it for a few friends and i know that it is very easy to do go give it hell
TR Profile
Myspace Profile
Old Apr 6, 2001 | 10:30 AM
Garrett's Avatar
pfft.....
thank you so mcuh my clutch is actually working again.... it even feels like it is grabbig harder now....
Old Apr 8, 2001 | 11:23 AM
RicerX's Avatar
Icy Hot Stuntin
Glad to see it worked.
