B20B piston questions
Old Feb 7, 2008 | 04:20 PM
importeclipsegst's Avatar
Default B20B piston questions
ok i found a nice set of Weisco pistons that will bump my b20/vtec motor to 11 to 1. but my question is will they fit on the stock rods?
Old Feb 7, 2008 | 05:45 PM
YBlegal's Avatar
Broke not Built
yes they should be a direct replacement.
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Feb 9, 2008 | 12:17 AM
StrictlyBusiness's Avatar
Mr. Stealyogirl
+1, But if your doing that, Pullin apart the motor and everything, just buy rods and ill highly reccamend the Endyne break in for pistons.
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Feb 9, 2008 | 12:32 AM
YBlegal's Avatar
Broke not Built
^ if your doing an N/A set-up you dont need aftermarket rods....and at 11:1 i highly doubt hes going boosted.....
Old Feb 9, 2008 | 06:08 AM
Eluzzionz's Avatar
^however he may want to sip on a bottle....in that case its just a lil bit of extra insurance..especially when u can find eagle rods for about 200 on here..
Old Feb 9, 2008 | 06:27 AM
YBlegal's Avatar
Broke not Built
^ if your looking for extra insurance are you really gonna buy used rods???
sorry but some things are just worth buying new if your gonna spend the money....
Old Feb 9, 2008 | 06:48 AM
Eluzzionz's Avatar
i didnt say used..and my bad..they are 250
https://www.tamparacing.com/forums/h...-250-00-a.html
Old Feb 9, 2008 | 01:00 PM
well yea im staying n/a and no bottle. just didnt want the 9.2:1 compression ratio with a b20b/b16 combo. so just wanted to get pistons, i was planning on a ls/vtec so i have already all the bearings, water pump, oil pump, oil pick-up, baffle, rings and rod bolts( just need girdle and gsr main's), but when the p30 pistons deal had fell through i found a cheap b20b block so everything useable except the rings. just wanted to bump up the compression a little. ill take all the extra torque i can!
Old Feb 9, 2008 | 01:50 PM
rangcrx's Avatar
engine building &best
i use thos on my builds for ls/vtec that way you dont need to change over to the 3 Gsr main caps
Untitled Document
i love AUTOZONE
Old Feb 9, 2008 | 05:48 PM
Untitled Document
i wont need to change to gsr mains with that girdle? not quite sure what you mean.
