need help no pulse to injectors 00 civic si
Old Feb 5, 2008 | 07:47 AM
amimaxima's Avatar
Default need help no pulse to injectors 00 civic si
I'm not getting a pulse to the injectors.
you can hear the fuel pump prime, all the ground wires under the hood are connected, i took put the p28 and installed the stock stock still nothing. the main fuel pump relay has to be good because the fuel pump primes, I check all fuses and relays.
I'm at a dead end I cant think of anything else to check
the car was working 100% fine and while driving it just shut off. and I came up to the conclusion that the injectors aren't getting a pulse.
Old Feb 5, 2008 | 07:50 AM
prymerintegra's Avatar
anything after market on it ???
Old Feb 5, 2008 | 09:33 AM
amimaxima's Avatar
pretty much everything
Old Feb 5, 2008 | 03:37 PM
DemonCivic's Avatar
if the injector driver in the ecu is good then it must be the module in the dizzy.
Old Feb 5, 2008 | 04:22 PM
amimaxima's Avatar
i have a chipped p28 in there and i thought it may have been the ecu so i put the stock ecu in there and it still didnt work
Old Feb 6, 2008 | 02:11 PM
DemonCivic's Avatar
must be the module in your dizzy, g/l
Old Feb 6, 2008 | 03:36 PM
cutty2fast's Avatar
boats and hoes!!
the injectors should have a constant power turn the key on and test for voltage, does your car have a injector resistor???
Your fucking slow!!
Old Feb 8, 2008 | 08:11 PM
lzylst's Avatar
Backprobe your injectors from the injector clip to the end where the dummy plug is on the drivers shock tower. Look for continuity from end to end. That dummy plug makes the circuit complete.
Vance @ 863-604-2139 for any questions
Old Feb 9, 2008 | 02:22 PM
freakasis's Avatar
are you getting spark?
how do you know the injectors arent firing?
are the cams turning?
