I know ,I know asking more questions
I have a fully built 95 Gsr head on a 2000 b16 block new timing belt and every bolt on you could think of .I had a few problem getting it to run properly ,fuel leaks,upside down head gaskets ,bad speed sensors the works. I finally got it running, idle was perfect fuel pressure was fine no more leaks and vtec was popping of hard as fuck,9200 rpms lovin life.
I pull up to a light im at idle you know 900 rpms to 1000 chillin and the car just dies , i (like a dumbass) thought it was a fuel issue cause i was low on fuel thought i ran out of gas so i kept cranking the motor over and over again nothing. I pop the hood get out check all of my wiring (fine) check everthing else good . I have a cut valve cover i look there and the exhaust cam is pointing straight up 12 o clock the intake is pointing towards the firewall at 4 o clock . What the hell could have locked up/came loose to cause this , i haven't torn it apart yet but the t belt has plenty of tension everythings snug. Im praying i haven't already bent those pretty stainless valves but what could have caused this? ANY IDEAS guys please . No shit talkers please.
how do you put a headgasket upside down?the bolts wont line up...but sounds to me like your tensioner is loose or the spring is not there
i love AUTOZONE
i love AUTOZONE
