cam/intake mani. choice???
ok first off im trying to get some thoughts on what cams, and intake manifold/TB setup i should use on my motor, also what injector size.
im not looking to drop a shit load of money, but still wanna get quality stuff.
heres my build, make your selection accordingly....
LS/Vtec
B18, stock crank/rods, ARP rod bolts, Endyn "RollerWave" high comp. pistons(supposed to be right at 12.5:1 in this set-up.
B16 head, with ITR cams/springs/retainers. supposidly shaved .040, B16 intake manifold/TB, and LS injectors.
this set-up has been tuned on 93 octane and been running for close to 40K miles or so. just looking to get a lil more out of it....
so lets hear the opinions on what cam and intake setup you guys would suggest, and also list the reason why you suggest it....
thanx guys, and rep is waiting for all those with helpfull info....
LS/Vtec
BC4's and a VICTOR X manifold.. You won't!!!
I'd go with a performer X manifold and S2 Pro 1's with skunk 2 pro series valve springs and retainers, manley valve locks.
Gracie Barra Clearwater
Vance, ill be getting my hands on a 255 very soon.
probably not if your daring me to....and just why should i choose this set-up over what others have suggested?
since when do you have to drop the tank to change a fuel pump lol?
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
as for your question troy. i've seen buddy club spec3's do really well and as for an intake mani. i'd either use a skun2 pro series or wait til they release their new composite intake mani.
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
As for the pro1's yes you really need to check valve to valve, retainer to guide seal, and valve to piston. The only one you really need to use special tools for is checking retainer to guide seal. If you degree them in to skunk to peak lift lobe centerlines then you will likely be safe but with the head milled 0.040" you really should be checking these things with any large cam. Everything but the valve to valve can be checked without removing the head, at skunk 2's recommended lobe centers valve to valve isn't really close.
