Header problems HELP PLEASE
Old Jan 30, 2008 | 05:21 AM
davinjensen013's Avatar
Default Header problems HELP PLEASE
I bought a used DC sport header off someone who told me it was for a B16 but i went to install the end of the header and the CAT dont line up what do i do??????????
Old Jan 30, 2008 | 11:05 AM
Old Renegade's Avatar
Cool Runnings
as long as it clears the oil pan you should be fine. get a test pipe made..also if it bolts to the bolt pattern of your head then it more than likely is for your motor.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Jan 30, 2008 | 12:27 PM
Jason2801's Avatar
It is what it is
^^+1, and yea a test pipe should fix your problem...I would recommend going with the OMNI test pipe as you can adjustable and twist it around to line up with your bolt pattern. If you get it make sure you order the correct one though cause they have the 2.5 inlet (which is for JDM headers) and 2.25 inlet (for USDM headers).
