good brake rotor and pad combo ?
i got a set of brembo blanks and pbr ultimates from:
Honda-Tech.com: Wheels, Tires, and Suspension: || FS: Brembo blank rotors + PBR Ultimate Ceramic brake pads, Best deal yet!! ||
and i have been really happy with them. they stop great, but they do put out a decent amount of dust.
Tirerack has a really good deal going on w/ the Brembo Replacement Rotors. aka, they're the same thing that are on the Evo, and they stop like a dream. Just combine them with a Hawk Pad, and you should be good to go.
"Success is 99% failure" -Soichiro Honda
thats what i use, i like the honda pads, they barely dust, dont squeak, arent expensive and last a long time. i also just use the oem rotors for the same reason and they're nice and meaty too!
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
meows meows
I replaced my stock lines with goodridge stainless and didnt really notice a difference.... i guess if the ol stockers were going bad youd notice it, but mine were still pretty good....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
power stop cross drilled rotors in the front and power stop cross drilled and slotted in the rear with autozone semi metalic pads all around. also my whole suspension front and rear is that of a integra and to top it off stainless steel braided brake lines all around. i discribe my stopping power like this: you could get whiplash from the forward momentum when you really need to stop!
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
I highly discourage ceramic pads as they fade at higher temps, and brakes tend to get hot really fast on hard stops/heavy decel from higher speeds... I had a really scary experience once in that exact scenario, and I'llnever run ceramics on a race car again. (this is just coming from a drag racing pov, auto x etc. may be way diff., i dont know...)
or maybe this setup
eBay Motors: 94-01 Acura Integra Drilled PBR Brake PADS & ROTORS (item 200198759090 end time Feb-15-08 11:05:40 PST)
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
