is it possible?
Old Jan 27, 2008 | 08:03 PM
radicallow's Avatar
Default is it possible?
is it possible to replace main bearring from bottom or does the motor need took apart?????
Old Jan 27, 2008 | 08:14 PM
Eluzzionz's Avatar
is it possible u can delete ur other two same exact threads?
Old Jan 27, 2008 | 09:47 PM
mtber's Avatar
Just take the motor out of the car & do it right. More then likely your crank is scarred.
Replacing a main bearing requires the removal of the crank which would pretty much require the removal of the tranny to remove the rear main seal.
Old Jan 28, 2008 | 03:49 AM
96ek's Avatar
I would not but it can be done.
