blowing fuses, any ideas?
tonight when i went to drive my 92 integra the intrument panel lights wouldnt work. i checked the fuse and and it was blown so i changed it, i turned the lights back on and it blew the fuse again. obviously i know some where its grounded out. i have no idea where to start looking can anyone help me out.
very common cause is from aftermarket stereo wiring.
Most aftermarket radios don't use the factory lighting feed and if you used an adapter harness that wire is unused.
Frequently I have seen these shorted out.
Wrap any open wire ends with tape to insulate.
FYI most adapter harnesses have this wire colored orange sometimes with a white stripe
Liar, you couldn't cut me deeper with a knife if you tried
