turbo guys chime in
I bought a Garrett T3 Super 60 externally wastegated. I want to make sure that this turbo is the right size for the power i want in a stock motor.
So far, I have a jdm b16 with S2 intake mani and TB. This is in a CRX.
Im looking for 250whp when im done on stock motor.
Will this turbo be fine for what i want??
1992 Honda Civic Si: SOLD
2003 VW Gti 1.8t: SOLD
Most recent: 88' B16 Turbo CRX: Totaled
PM me if you know me!
That turbo is fine for 250, It spools nice on a sohc non vtec.So im sure it is a little undersized for a dohc vtec. Maybe you would want to atleast put a .63 exhaust housing if it doesnt have one.
1998 crv daily beater
these are the specs i found on spoolin performance:
COMPRESSOR SPECS: hi performance 60 trim WHEEL .42 A/R FLOW: 35lbs/min 422cfm TURBINE SPECS: 4bolt Turbine housing 68 TRIM WHEEL .48 A/R
Probably going to get choked off a bit in the upper rpm range but should work ok with that setup.
Gracie Barra Clearwater
as long as i hit low-mid 12's on slicks, ill be happy for a while. should i do anything to the motor? and how much boost is safe to run on a good tune?
The turbo is kinda going to max out a little over 250 so run whatever boost you need to get there.
slicks should get u 12s. on a good tune u can run it internally stock n make 250 to the wheels. im sure a bigger turbo would help but itd b a mean lil street car.
thats all i want.. for now. i would be very happy with a 12 sec street car making 250 until i have enough money to go with a bigger turbo and built motor.
You will need to replace the stock map sensor with a map sensor capable of reading higher. I would recommend the AEM 3.5 bar, GM 3 bar or Motorola 2.5 bar
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
