Piston ring question
Old Jan 21, 2008 | 11:51 AM
89crxsir's Avatar
Default Piston ring question
would piston rings and bearings for a c1 and a c5 work in a ls?? (92 teg)
Old Jan 21, 2008 | 02:21 PM
EGKID's Avatar
The piston rings are interchangeable, but the bearings are not because the LS crankshaft journals are wider than the GSR and Type R. If your ever not sure just compare the part numbers.
Ricky
Old Jan 22, 2008 | 01:14 PM
hatchattack's Avatar
The piston rings and pistons interchange. The blocks are essentialy the same. I'm running ITR pistons in my ls block no problem.
