Major Problem Help Ma Fellow Peps!
Old Jan 17, 2008 | 05:23 AM
bIgSaM's Avatar
tegra bitches
Default Major Problem Help Ma Fellow Peps!
wen i drive ma car and push tha bitch it b makin ma headlights get bright and it had blew up 2 set in the past week and wen it does this it sumtimes shut ma radio off also. i was planin to get hid buh scared it might blow
Old Jan 17, 2008 | 09:40 AM
Old Renegade's Avatar
Cool Runnings
proper english please.. maybe you have a short somewhere. my .02 cents
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Jan 17, 2008 | 10:05 AM
Liquid's Avatar
is this guy for real?
Old Jan 18, 2008 | 04:33 AM
bIgSaM's Avatar
tegra bitches
ok my fault i was rushing to go to work when i wrote that. ok i got a 90 teg teg and it has been actin up in the last month, im not sure if its the alternator buh when im drivin and step on the gas the headlight gets brighter and it blew up my light bulbs that i jus bought last week.
any help be appriciated
Old Jan 19, 2008 | 09:38 PM
bIgSaM's Avatar
tegra bitches
help
Old Jan 20, 2008 | 06:44 AM
DemonCivic's Avatar
sounds like the voltage regulator in your alternator is bad and allowing to much of a charge. verify with a multi meter before replacing.
Old Jan 20, 2008 | 02:35 PM
bIgSaM's Avatar
tegra bitches
you tink i should replace it or i can fix it or sumthing
Old Jan 20, 2008 | 03:20 PM
DemonCivic's Avatar
connect a meter to your battery, start your car, check how many volts are coming from the alt, rev the gas and see the change. if it is more than 13-14.5 volts, the regulator is bad and you need a new alt. g/l
Old Jan 21, 2008 | 07:19 AM
bIgSaM's Avatar
tegra bitches
tanx man preciated
Old Jan 21, 2008 | 07:25 AM
Liquid's Avatar
Originally Posted by bIgSaMNiGgA
thank you sir. I appreciate it
fixed,
