Car running like A$$
Old Jan 14, 2008 | 04:38 PM
-OneFastREX-'s Avatar
Growe Motorsports
Default Car running like A$$
Ok i have a b18b1.... I had stock injectors in my car then i left my car at my shop and someone desided to put 440 rc injectors in my car.. I didnt find out till after i started it up and it sounded like garbage. now i took them out and put in the stock ones and it doesnt want to run right. sometimes runs on three cylinders then two then three again. i replaced the spark plugs but no change... any ideas on how to fix this?
Growe Motorsports Racing
C.T. Photography
REP IS ALWAYS APPRECIATED AND RETURNED!
Old Jan 14, 2008 | 04:50 PM
88RedRex's Avatar
Protected Taurus .45/.410
did you make sure the new injectors you put in were clean and not dirty and clogged
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
Old Jan 14, 2008 | 04:51 PM
Growe Motorsports
I just put in the stock ones that where taken out back in.
C.T. Photography
Old Jan 14, 2008 | 04:54 PM
StreetBlitz's Avatar
B Tuned CRX
re-set your ecu. and make sure the clips are on the correct injector.
Old Jan 14, 2008 | 05:04 PM
nocomply540's Avatar
is retired...
^damn you beat me to it!
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Jan 14, 2008 | 05:33 PM
96ek's Avatar
Resistor Box??
Old Jan 14, 2008 | 07:18 PM
Growe Motorsports
reset ecu and clips are correct. Car is obdo ... dont need a resitor box. If i plug in a resitor box the ecu throws the injector code.
C.T. Photography
Old Jan 14, 2008 | 08:23 PM
is retired...
^if the car is obdo you do need the resistor box. Look it up in a manual on how to check them out. Or if you have a spare one swap it in.
Old Jan 15, 2008 | 05:10 AM
96ek's Avatar
The reason why i said resistor box is because you should have one if your obd0 and think those 440s are obd1 you could have fried your resistor box or injectors.Let us know what happens..
Old Jan 15, 2008 | 02:52 PM
Growe Motorsports
car doesnt start when i put the resistor box on... it runs when i took one of my other resitor boxes and cut the wires and tapped them all together... ran perfect with those (before this sh!t happend)
C.T. Photography
