need help with my bros gsr
ok here is the deal...4 sum reason hes throwing a cel only when his car goes abouve 60mph. its the knock sensor code. he has a bad motor mount...could this be whats setting off the cel?
It is doubtful, check the connection between the engine harness & the knock sensor/ecu. If the connection is good, replace the knock sensor or simply have the ecu chipped to remove the knock sensor as it is pointless.
what grade gas is he running?
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
engine building &best
on
is that the only code?there is no misFire code or anyhting else?
i love AUTOZONE
i love AUTOZONE
