distrubutor question Obd0-Obd1 conversion problems .....help!!
Old Jan 10, 2008 | 06:43 PM
Honda_Redemption's Avatar
code 52!!
Default distrubutor question Obd0-Obd1 conversion problems .....help!!
I just made some jumpers for my obd 0 car using this link----
Honda-Tech.com: Honda CRX / EF Civic: Non OBD to OBD1 conversion (By: Gold EF)
and triple checked it ......
the motor is a z6
i turn the key and it runs like shit for a few seconds then turns off....and my tach is jumping around from 6-8 grand at idle
anyone have any insight or ideas please lmk .....I"m not to sure about the dizzy its a gsr dizzy
CAN I RUN A GSR DIZZY ON A SOHC??????.....IF NOT THAT IS MY PROBLEM
Thanks in advanced and all help will be rep'd thanks again
Old Jan 10, 2008 | 07:11 PM
Eluzzionz's Avatar
gsr dizzy is ur problem..
Old Jan 11, 2008 | 06:42 AM
code 52!!
Anyone else?
Old Jan 11, 2008 | 07:37 AM
Bite_Size's Avatar
עִמָּנוּ אֵל
how did u figure that diagram out if u don't mind me askin. i'm actually interested in making my own.
Old Jan 11, 2008 | 08:03 AM
Eluzzionz's Avatar
im almost 100% sure u cant use a dohc dizzy on a sohc..
Old Jan 11, 2008 | 09:19 AM
code 52!!
Ok thanks you've been repd
Old Jan 11, 2008 | 09:22 AM
code 52!!
And bite size I suggest buying one it took 5 hours to make with all the solder and heat shrink if you still wanna make it PM me and ill send you the rest of the links I used that helped
